Date/Time: Fri, 22 Nov 2024 17:14:28 +0000
Current Delta Volume
View Count: 125
[2024-10-04 20:33:27] |
Eranox - Posts: 26 |
Hi, I know that I can add the Current Total Volume coloumn to the DOM. I'd like to add also a Current Delta Volume coloumn.. is it possible? Thanks |
[2024-10-04 20:46:40] |
John - SC Support - Posts: 36221 |
No, there is no "Current Delta Volume" column.
[2024-10-04 21:07:57] |
Can you consider the possibility to add it?
[2024-10-04 21:13:42] |
We take all suggestions, but we can not say when we would get to any particular item.
[2024-10-04 21:27:15] |
In the meantime, is there a way to manually reset a delta profile on the chart?
[2024-10-06 17:35:53] |
Refer to the following: Volume By Price Reset Button For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
