Date/Time: Wed, 27 Nov 2024 13:05:30 +0000
Error ? Problem
View Count: 966
[2014-09-04 21:44:11]
77293A - Posts: 8
I see one problem, a variety of instruments Following error.
is set to 1000 delta per bar, Kazaa bar should be at + - 1000 delta volumen.
During the session, there are bars that do not have this variation.
example, selected
imageF.US.QOV14 [C] Delta 1000v #2 2014-09-04 23_42_20.708.png / V - Attached On 2014-09-04 21:43:58 UTC - Size: 80.25 KB - 335 views
[2014-09-05 05:49:56]
Make sure you have a tick by tick data configuration:
https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php
And uncheck New Bar at Session Start in Chart >> Chart Settings.
[2014-09-05 08:45:33]
77293A - Posts: 8
That's my settings, see for yourself
imageaaaaaaaaa.PNG / V - Attached On 2014-09-05 08:45:09 UTC - Size: 158.87 KB - 341 views
imagebbbbb.PNG / V - Attached On 2014-09-05 08:45:23 UTC - Size: 142.1 KB - 349 views
[2014-09-05 09:21:01]
Uncheck New Bar at Session Start in Chart >> Chart Settings.
