Date/Time: Fri, 22 Nov 2024 17:09:41 +0000
How to reset/remove space to the right of Y axis on charts
View Count: 70
[2024-10-04 19:48:10]
User763335 - Posts: 82
Hello
I frequently run into this issue of blank space taking up space, to the right of Y axis on the charts, as shown in the attached screenshot. How do I reset and remove this space. I've set the formatting of the individual indicators to the most compact format as possible(eg Large Integer with suffix, 1, 0.1 etc). Have also reset the scaling on each of the indicators and set them to automatic.
pls advise, thanks
Private File
[2024-10-04 20:20:14]
John - SC Support - Posts: 36221
That space should automatically update based on the actual values of the studies.
Select "Chart >> Recalculate" to force a full recalculation which will update the scales.
If the above does not work, then check to see if you have any other columns displayed in that area that are not showing anything. Refer to the following:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
If none of the above work, then please get us that chart by following the instructions at the following link and we will take a look:
