Date/Time: Fri, 22 Nov 2024 17:11:53 +0000
Supported Broker Connections for CME Non-Professional Certification
View Count: 72
[2024-10-04 17:41:16] |
LongShortz - Posts: 7 |
I read through the documentation and one thing is not quite clear to me. In the section where it describes the process of logging in to a live funded trading account at least once a month for certification purposes, it seems to indicate that only 3 brokers would be supported. Is that truly the limitation or can I use my Amp Futures account for this purpose?
[2024-10-04 18:15:53] |
John - SC Support - Posts: 36221 |
Any broker that Sierra Chart supports can be used for this. This includes AMP. We think the section you were referencing with the 3 brokers is for the "Simple Solution", where those 3 brokers will open an account for a minimum amount allowing you to have an account that will qualify for the CME Group's Non-Professional requirement. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
