Date/Time: Fri, 22 Nov 2024 11:16:09 +0000
Unable to login to my Ritmic live date feed
View Count: 99
[2024-10-04 16:21:27] |
User938135 - Posts: 2 |
2024-10-04 13:21:32.823 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-10-04 13:21:32.823 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2024-10-04 13:21:32.823 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2024-10-04 13:21:32.824 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-10-04 13:21:32.824 | DTC Client socket (1) | New receive buffer size: 0 2024-10-04 13:21:32.824 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-10-04 13:21:32.844 | File >> Disconnect selected. 2024-10-04 13:21:32.844 | DTC Client socket (1) | CloseSocket call. 2024-10-04 13:21:32.844 | DTC Client socket (1) | Closed. 2024-10-04 13:21:32.845 | Rithmic Direct - DTC | Disconnected. 2024-10-04 13:21:52.849 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | Creating socket. Using TLS 1.2. 2024-10-04 13:21:52.849 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | New receive buffer size: 0 2024-10-04 13:21:52.849 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | Connecting to IP: 216.66.0.130. 2024-10-04 13:21:54.241 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 75789 2024-10-04 13:21:54.245 | Rithmic Direct - DTC | Processed connection points. Count: 324 2024-10-04 13:21:54.497 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | CloseSocket call. 2024-10-04 13:21:54.497 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | Shutdown started. Waiting for graceful close. 2024-10-04 13:21:54.745 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | Socket gracefully closed by remote side. 2024-10-04 13:21:54.745 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | Closed. |
[2024-10-04 17:08:56] |
Sierra_Chart Engineering - Posts: 17143 |
This log is not complete. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-07 04:55:29] |
2024-10-07 04:51:43.958 | Trade activity files set size: 13 2024-10-07 04:51:43.993 | Rithmic Direct - DTC | Processed connection points. Count: 324 2024-10-07 04:51:44.202 | Created the DTC Protocol server. 2024-10-07 04:51:44.204 | DTC Protocol Server listening on port 11099. 2024-10-07 04:51:44.204 | Reading Internal Order ID file. 2024-10-07 04:51:44.209 | Reading Trade Orders file. 2024-10-07 04:51:44.216 | Reading Trade Positions file. 2024-10-07 04:51:44.222 | Reading Trade Account Data files. 2024-10-07 04:51:44.229 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. 2024-10-07 04:51:44.229 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0 2024-10-07 04:51:44.229 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130. 2024-10-07 04:51:44.235 | Software version: 2671 64-bit 2024-10-07 04:51:44.235 | Primary Thread ID: 32872 2024-10-07 04:51:44.235 | Usage end date: 2025-10-07 2024-10-07 04:51:44.235 | Enabled for: Advanced Features 2. 2024-10-07 04:51:44.235 | Enabled for: Sierra Chart Historical Data Service. 2024-10-07 04:51:44.235 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-10-07 04:51:44.235 | Enabled for: Delayed Denali Exchange Data Feed. 2024-10-07 04:51:44.235 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-10-07 04:51:44.235 | Current selected Data/Trading service: Rithmic Direct - DTC 2024-10-07 04:51:44.235 | Custom symbol settings values: enabled 2024-10-07 04:51:44.235 | Chart Update Interval: 400 2024-10-07 04:51:44.235 | Intraday Data Storage Time Unit: 0 2024-10-07 04:51:44.235 | Time Zone: +00:00:00 (UTC+00) 2024-10-07 04:51:44.235 | 2024-10-07 04:51:44 Local computer time in UTC 2024-10-07 04:51:44.235 | 2024-10-07 04:51:44 Local computer time in SC Time Zone 2024-10-07 04:51:44.235 | 2024-10-07 04:51:43 Server time in UTC 2024-10-07 04:51:44.235 | Local computer UTC time and Server UTC time difference: 0 seconds. 2024-10-07 04:51:44.235 | Program path: C:\SierraChart\ 2024-10-07 04:51:44.235 | Data Files path: C:\SierraChart\Data\ 2024-10-07 04:51:44.236 | OS Version Number: 10.0 2024-10-07 04:51:44.236 | Locale Setting: C 2024-10-07 04:51:44.241 | DLLs: UserContributedStudies_64.dll 2024-10-07 04:51:44.241 | Allowed protected custom studies: 2024-10-07 04:51:44.241 | Crash reporter started: true 2024-10-07 04:51:44.241 | 2024-10-07 04:51:44.241 | Created the DTC Protocol historical data server. 2024-10-07 04:51:44.242 | HD Server Manager | Listening on port 11098. 2024-10-07 04:51:44.243 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. 2024-10-07 04:51:44.344 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-10-07 04:51:44.527 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-10-07 04:51:44.527 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2024-10-07 04:51:44.881 | Received 5 login tokens. 2024-10-07 04:51:45.340 | Symbol settings MD5 received. Request ID: 1. 2024-10-07 04:51:45.340 | Symbol settings are up-to-date for rithmic_v2.trading. 2024-10-07 04:51:45.534 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 75789 2024-10-07 04:51:45.535 | Rithmic Direct - DTC | Processed connection points. Count: 324 2024-10-07 04:51:45.798 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call. 2024-10-07 04:51:45.798 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. 2024-10-07 04:51:46.017 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. 2024-10-07 04:51:46.017 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed. 2024-10-07 04:51:46.747 | Requested user files to download. 2024-10-07 04:51:48.742 | 2024-10-07 04:51:48.743 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-10-07 04:51:48.743 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2024-10-07 04:51:48.745 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2024-10-07 04:51:49.780 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-10-07 04:51:49.780 | DTC Client socket (1) | New receive buffer size: 0 2024-10-07 04:51:49.780 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-10-07 04:51:50.020 | Rithmic Direct - DTC | Network connection to server complete. 2024-10-07 04:51:50.020 | Rithmic Direct - DTC | Starting socket receive thread. 2024-10-07 04:51:50.020 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-10-07 04:51:50.020 | Rithmic Direct - DTC | Sending logon request message. 2024-10-07 04:51:50.744 | Rithmic Direct - DTC | Received logon response. 2024-10-07 04:51:50.744 | Rithmic Direct - DTC | Server Name: . 2024-10-07 04:51:50.744 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-10-07 04:51:50.744 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-10-07 04:51:50.744 | Rithmic Direct - DTC | Failed connections: 1 2024-10-07 04:51:50.744 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-10-07 04:51:50.744 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-10-07 04:51:50.781 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-10-07 04:51:50.782 | DTC Client socket (1) | CloseSocket call. 2024-10-07 04:51:50.782 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-10-07 04:51:50.782 | Rithmic Direct - DTC | Disconnected. 2024-10-07 04:51:50.782 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-10-07 04:51:51.019 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-10-07 04:51:51.019 | DTC Client socket (1) | Closed. 2024-10-07 04:51:51.966 | Files to Open on Startup | Opening file: VWAPs.Cht 2024-10-07 04:51:52.107 | Loading DLL: C:\SierraChart\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffc1aee0000 2024-10-07 04:51:52.415 | F.US.EPZ24 [CBV] 1 Day #1 | Reloading chart. 2024-10-07 04:51:52.415 | F.US.EPZ24 [CBV] 1 Day #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:52.415 | F.US.EPZ24 [CBV] 1 Day #1 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:52.479 | F.US.EPZ24 [CBV] 30 Min #2 | Reloading chart. 2024-10-07 04:51:52.479 | F.US.EPZ24 [CBV] 30 Min #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:52.479 | F.US.EPZ24 [CBV] 30 Min #2 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:52.513 | F.US.EPZ24 [CBV] 5 Min #3 | Reloading chart. 2024-10-07 04:51:52.513 | F.US.EPZ24 [CBV] 5 Min #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:52.513 | F.US.EPZ24 [CBV] 5 Min #3 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:52.527 | Files to Open on Startup | Opening file: VPs.Cht 2024-10-07 04:51:52.907 | F.US.EPZ24 [CBV] 1 Min #3 | Reloading chart. 2024-10-07 04:51:52.907 | F.US.EPZ24 [CBV] 1 Min #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:52.907 | F.US.EPZ24 [CBV] 1 Min #3 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:52.946 | F.US.EPZ24 [CBV] 30 Min #1 | Reloading chart. 2024-10-07 04:51:52.946 | F.US.EPZ24 [CBV] 30 Min #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:52.946 | F.US.EPZ24 [CBV] 30 Min #1 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:52.971 | F.US.EPZ24 [CBV] 1 Day #2 | Reloading chart. 2024-10-07 04:51:52.971 | F.US.EPZ24 [CBV] 1 Day #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:52.971 | F.US.EPZ24 [CBV] 1 Day #2 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:53.010 | F.US.EPZ24 [CBV] Point & Figure 1-12 #4 | Reloading chart. 2024-10-07 04:51:53.010 | F.US.EPZ24 [CBV] Point & Figure 1-12 #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:53.010 | F.US.EPZ24 [CBV] Point & Figure 1-12 #4 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:53.026 | Files to Open on Startup | Opening file: DOMs.Cht 2024-10-07 04:51:53.140 | F.US.EPZ24 [CBV] 500 Volume #1 | Reloading chart. 2024-10-07 04:51:53.140 | F.US.EPZ24 [CBV] 500 Volume #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:53.140 | F.US.EPZ24 [CBV] 500 Volume #1 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:53.165 | F.US.EPZ24/F.US.MESZ24 #2 | Reloading chart. 2024-10-07 04:51:53.168 | F.US.EPZ24/F.US.MESZ24 #2 | StartDateTimeForLoadingOrderFills: 2024-09-23 00:00:00 2024-10-07 04:51:53.207 | F.US.EPZ24/F.US.MESZ24 #2 | Chart data loading complete. 2024-10-07 04:51:53.217 | Files to Open on Startup | Opening file: Template Prep.Cht 2024-10-07 04:51:53.304 | F.US.EPZ24 [CBV] Point & Figure 1-12 #3 | Reloading chart. 2024-10-07 04:51:53.304 | F.US.EPZ24 [CBV] Point & Figure 1-12 #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:53.304 | F.US.EPZ24 [CBV] Point & Figure 1-12 #3 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:53.347 | F.US.EPZ24 [CBV] 30 Min #1 | Reloading chart. 2024-10-07 04:51:53.347 | F.US.EPZ24 [CBV] 30 Min #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:53.347 | F.US.EPZ24 [CBV] 30 Min #1 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:53.410 | F.US.EPZ24 [CBV] Daily #2 | Reloading chart. 2024-10-07 04:51:53.410 | F.US.EPZ24 [CBV] Daily #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:53.410 | F.US.EPZ24 [CBV] Daily #2 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:53.447 | F.US.EPZ24 [CBV] 5 Min #4 | Reloading chart. 2024-10-07 04:51:53.447 | F.US.EPZ24 [CBV] 5 Min #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:53.447 | F.US.EPZ24 [CBV] 5 Min #4 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:53.518 | F.US.EPZ24 [CBV] 30 Min #5 | Reloading chart. 2024-10-07 04:51:53.518 | F.US.EPZ24 [CBV] 30 Min #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:53.518 | F.US.EPZ24 [CBV] 30 Min #5 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:53.552 | F.US.EPZ24 [CBV] 1 Day #6 | Reloading chart. 2024-10-07 04:51:53.552 | F.US.EPZ24 [CBV] 1 Day #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:53.552 | F.US.EPZ24 [CBV] 1 Day #6 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:53.602 | Files to Open on Startup | Opening file: Template.Cht 2024-10-07 04:51:54.027 | F.US.EPZ24 [CBV] 3 Min #1 | Reloading chart. 2024-10-07 04:51:54.027 | F.US.EPZ24 [CBV] 3 Min #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:54.027 | F.US.EPZ24 [CBV] 3 Min #1 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:54.059 | F.US.EPZ24 [CBV] 30 Min #2 | Reloading chart. 2024-10-07 04:51:54.059 | F.US.EPZ24 [CBV] 30 Min #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:54.059 | F.US.EPZ24 [CBV] 30 Min #2 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:54.088 | F.US.EPZ24 [CBV] 5 Min #5 | Reloading chart. 2024-10-07 04:51:54.088 | F.US.EPZ24 [CBV] 5 Min #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:54.088 | F.US.EPZ24 [CBV] 5 Min #5 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:54.171 | F.US.EPZ24 [CBV] 500 Volume #8 | Reloading chart. 2024-10-07 04:51:54.171 | F.US.EPZ24 [CBV] 500 Volume #8 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:51:54.171 | F.US.EPZ24 [CBV] 500 Volume #8 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:51:54.188 | Files to Open on Startup | Opening file: VPs.Cht 2024-10-07 04:51:58.049 | F.US.EPZ24 [CBV] 1 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-09-23 11:16:00. Next Bar Date Time: 2024-09-23 11:10:00. Filename: F.US.EPZ24.scid 2024-10-07 04:51:58.124 | F.US.EPZ24 [CBV] 5 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-09-23 11:15:00. Next Bar Date Time: 2024-09-23 11:10:00. Filename: F.US.EPZ24.scid 2024-10-07 04:51:58.428 | F.US.EPZ24 [CBV] 5 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-09-23 11:15:00. Next Bar Date Time: 2024-09-23 11:10:00. Filename: F.US.EPZ24.scid 2024-10-07 04:51:58.799 | F.US.EPZ24 [CBV] 500 Volume #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-09-23 11:16:03. Next Bar Date Time: 2024-09-23 11:10:55. Filename: F.US.EPZ24.scid 2024-10-07 04:51:59.567 | F.US.EPZ24 [CBV] 3 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-09-23 11:15:00. Next Bar Date Time: 2024-09-23 11:09:00. Filename: F.US.EPZ24.scid 2024-10-07 04:52:00.554 | F.US.EPZ24 [CBV-D] Daily #2 | Chart data loading complete. 2024-10-07 04:52:00.565 | F.US.EPZ24 [CBV-D] Point & Figure 1-12 #4 | StartDateTimeForLoadingOrderFills: 2024-09-13 00:00:00 2024-10-07 04:52:00.775 | F.US.EPZ24 [CBV-D] Point & Figure 1-12 #4 | Chart data loading complete. 2024-10-07 04:52:00.777 | F.US.EPZ24 [CBV] 5 Min #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-09-23 11:15:00. Next Bar Date Time: 2024-09-23 11:10:00. Filename: F.US.EPZ24.scid 2024-10-07 04:52:00.924 | F.US.EPZ24 [CBV-D] 30 Min #1 | Chart data loading complete. 2024-10-07 04:52:00.926 | F.US.EPZ24 [CBV-D] Point & Figure 1-12 #3 | StartDateTimeForLoadingOrderFills: 2024-09-13 00:00:00 2024-10-07 04:52:00.931 | F.US.EPZ24 [CBV-D] Point & Figure 1-12 #3 | Chart data loading complete. 2024-10-07 04:52:00.935 | Loading market depth data. 2024-10-07 04:52:00.948 | F.US.EPZ24 [CBV-D] 1 Day #1 | StartDateTimeForLoadingOrderFills: 2024-09-13 00:00:00 2024-10-07 04:52:00.951 | F.US.EPZ24 [CBV-D] 1 Day #1 | Chart data loading complete. 2024-10-07 04:52:00.974 | F.US.EPZ24 [CBV-D] 30 Min #2 | Chart data loading complete. 2024-10-07 04:52:01.016 | F.US.EPZ24 [CBV-D] 1 Min #3 | StartDateTimeForLoadingOrderFills: 2024-09-13 00:00:00 2024-10-07 04:52:01.131 | F.US.EPZ24 [CBV] 500 Volume #8 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-09-23 11:16:03. Next Bar Date Time: 2024-09-23 11:10:55. Filename: F.US.EPZ24.scid 2024-10-07 04:52:01.226 | F.US.EPZ24 [CBV-D] 1 Min #3 | Chart data loading complete. 2024-10-07 04:52:01.249 | Loaded depth data records for F.US.EPZ24 2024-09-18 from 2024-09-18 09:30:00.000000 to 2024-09-18 10:04:25.461791. 2024-10-07 04:52:01.265 | F.US.EPZ24 [CBV-D] 5 Min #4 | Chart data loading complete. 2024-10-07 04:52:01.296 | Loaded depth data records for F.US.EPZ24 2024-09-19 from 00:00:00.000000 to 00:00:00.000000. 2024-10-07 04:52:01.485 | F.US.EPZ24 [CBV-D] 1 Day #2 | Chart data loading complete. 2024-10-07 04:52:01.492 | F.US.EPZ24 [CBV-D] 30 Min #1 | Chart data loading complete. 2024-10-07 04:52:01.525 | F.US.EPZ24 [CBV-D] 5 Min #3 | Chart data loading complete. 2024-10-07 04:52:01.533 | F.US.EPZ24 [CBV-D] 30 Min #2 | Chart data loading complete. 2024-10-07 04:52:01.535 | F.US.EPZ24 [CBV-D] 3 Min #1 | StartDateTimeForLoadingOrderFills: 2024-09-13 00:00:00 2024-10-07 04:52:01.557 | F.US.EPZ24 [CBV-D] 3 Min #1 | Chart data loading complete. 2024-10-07 04:52:01.921 | Loaded depth data records for F.US.EPZ24 2024-09-25 from 2024-09-25 12:56:51.812000 to 2024-09-25 17:59:59.814000. 2024-10-07 04:52:02.409 | F.US.EPZ24 [CBV-D] 30 Min #5 | Chart data loading complete. 2024-10-07 04:52:02.529 | Using symbol data fast lookup vector 2024-10-07 04:52:02.529 | Starting DelayedDownloadMonitoringTimer 2024-10-07 04:52:02.529 | Starting HDTimeoutTimer 2024-10-07 04:52:02.529 | Added historical Intraday data request for F.US.EPZ24 to the queue. 2024-10-07 04:52:02.529 | Intraday data recording state for symbol F.US.EPZ24 is set to download 'Pending'. 2024-10-07 04:52:02.532 | Triggering next historical data download in queue. 2024-10-07 04:52:02.534 | HD Request # 1 | Downloading Intraday chart data for F.US.EPZ24 to the file F.US.EPZ24.scid. Service: rithmic_v2.trading 2024-10-07 04:52:02.535 | HD Request # 1 | Download start date-time: 2024-09-27 14:05:30.000000. File last date-time: 2024-09-27 14:05:30.342004 2024-10-07 04:52:02.535 | HD Request # 1 | Using server: rsc.rithmic.com port 50530. Use encryption. 2024-10-07 04:52:02.535 | Socket (1) | Creating socket. Using TLS 1.2. 2024-10-07 04:52:02.535 | Socket (1) | New receive buffer size: 0 2024-10-07 04:52:02.535 | Socket (1) | Connecting to IP: 216.57.156.163. 2024-10-07 04:52:02.679 | F.US.EPZ24 [CBV-D] 5 Min #5 | Chart data loading complete. 2024-10-07 04:52:02.743 | F.US.EPZ24 [CBV-D] 1 Day #6 | Chart data loading complete. 2024-10-07 04:52:02.773 | HD Request # 1 | Sending historical data logon request message. 2024-10-07 04:52:02.785 | Loaded depth data records for F.US.EPZ24 2024-09-26 from 2024-09-26 11:04:35.622000 to 2024-09-26 15:38:44.415703. 2024-10-07 04:52:02.919 | Loading market depth data. 2024-10-07 04:52:02.984 | Added historical Daily data request for F.US.EPZ24 to the queue. 2024-10-07 04:52:02.984 | Triggering next historical data download in queue. 2024-10-07 04:52:02.989 | 2024-10-07 04:52:02.994 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-10-07 04:52:02.994 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2024-10-07 04:52:02.994 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2024-10-07 04:52:02.995 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-10-07 04:52:02.995 | DTC Client socket (3) | New receive buffer size: 0 2024-10-07 04:52:02.995 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2024-10-07 04:52:03.237 | Loaded depth data records for F.US.EPZ24 2024-09-18 from 2024-09-18 09:30:00.000000 to 2024-09-18 10:04:25.461791. 2024-10-07 04:52:03.248 | Rithmic Direct - DTC | Network connection to server complete. 2024-10-07 04:52:03.248 | Rithmic Direct - DTC | Starting socket receive thread. 2024-10-07 04:52:03.248 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-10-07 04:52:03.248 | Rithmic Direct - DTC | Sending logon request message. 2024-10-07 04:52:03.270 | Loaded depth data records for F.US.EPZ24 2024-09-19 from 00:00:00.000000 to 00:00:00.000000. 2024-10-07 04:52:03.320 | Loaded depth data records for F.US.EPZ24 2024-09-27 from 2024-09-27 09:30:12.298000 to 2024-09-27 10:05:30.342000. 2024-10-07 04:52:03.323 | F.US.EPZ24 [CBV-D] 500 Volume #1 | StartDateTimeForLoadingOrderFills: 2024-09-13 00:00:00 2024-10-07 04:52:03.345 | F.US.EPZ24 [CBV-D] 500 Volume #1 | Chart data loading complete. 2024-10-07 04:52:03.491 | Socket (1) | CloseSocket call. 2024-10-07 04:52:03.491 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-10-07 04:52:03.511 | HD Request # 1 | Error downloading historical Intraday data for F.US.EPZ24. Historical data logon error: permission denied 2024-10-07 04:52:03.512 | Added historical Intraday data request for F.US.EPZ24 to the queue. 2024-10-07 04:52:03.512 | Triggering next historical data download in queue. 2024-10-07 04:52:03.512 | Historical data download thread signaled to stop. 2024-10-07 04:52:03.512 | HD Request # 1 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.EPZ24 2024-10-07 04:52:03.512 | HD Request # 1 | Completion time: 1s. 2024-10-07 04:52:03.512 | 2024-10-07 04:52:03.512 | HD Request # 2 | Downloading Intraday chart data for F.US.EPZ24 to the file F.US.EPZ24.scid. Service: rithmic_v2.trading 2024-10-07 04:52:03.512 | HD Request # 2 | Download start date-time: 2024-09-27 14:05:30.000000. File last date-time: 2024-09-27 14:05:30.342004 2024-10-07 04:52:03.512 | HD Request # 2 | Using server: rsc.rithmic.com port 50530. Use encryption. 2024-10-07 04:52:03.513 | Socket (4) | Creating socket. Using TLS 1.2. 2024-10-07 04:52:03.513 | Socket (4) | New receive buffer size: 0 2024-10-07 04:52:03.513 | Socket (4) | Connecting to IP: 216.57.156.163. 2024-10-07 04:52:03.714 | Loaded depth data records for F.US.EPZ24 2024-09-25 from 2024-09-25 12:56:51.812000 to 2024-09-25 17:59:59.814000. 2024-10-07 04:52:03.731 | F.US.EPZ24 [CBV-D] 500 Volume #1 | Reloading chart. 2024-10-07 04:52:03.731 | F.US.EPZ24 [CBV-D] 500 Volume #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:52:03.731 | F.US.EPZ24 [CBV-D] 500 Volume #1 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:52:03.736 | Socket (1) | Socket gracefully closed by remote side. 2024-10-07 04:52:03.736 | Socket (1) | Closed. 2024-10-07 04:52:03.788 | HD Request # 2 | Sending historical data logon request message. 2024-10-07 04:52:04.012 | Rithmic Direct - DTC | Received logon response. 2024-10-07 04:52:04.012 | Rithmic Direct - DTC | Server Name: . 2024-10-07 04:52:04.012 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-10-07 04:52:04.012 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-10-07 04:52:04.012 | Rithmic Direct - DTC | Failed connections: 2 2024-10-07 04:52:04.012 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-10-07 04:52:04.012 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-10-07 04:52:04.126 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-10-07 04:52:04.126 | DTC Client socket (3) | CloseSocket call. 2024-10-07 04:52:04.127 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2024-10-07 04:52:04.127 | Rithmic Direct - DTC | Disconnected. 2024-10-07 04:52:04.127 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-10-07 04:52:04.382 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-10-07 04:52:04.382 | DTC Client socket (3) | Closed. 2024-10-07 04:52:04.530 | Loaded depth data records for F.US.EPZ24 2024-09-26 from 2024-09-26 11:04:35.622000 to 2024-09-26 15:38:44.415703. 2024-10-07 04:52:04.576 | Socket (4) | CloseSocket call. 2024-10-07 04:52:04.576 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-10-07 04:52:04.584 | HD Request # 2 | Error downloading historical Intraday data for F.US.EPZ24. Historical data logon error: permission denied 2024-10-07 04:52:04.585 | Added historical Intraday data request for F.US.EPZ24 to the queue. 2024-10-07 04:52:04.585 | Intraday data recording state for symbol F.US.EPZ24 is set to download 'Pending'. 2024-10-07 04:52:04.585 | Triggering next historical data download in queue. 2024-10-07 04:52:04.585 | Historical data download thread signaled to stop. 2024-10-07 04:52:04.585 | HD Request # 2 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.EPZ24 2024-10-07 04:52:04.585 | HD Request # 2 | Completion time: 1s. 2024-10-07 04:52:04.585 | 2024-10-07 04:52:04.585 | HD Request # 3 | Downloading Intraday chart data for F.US.EPZ24 to the file F.US.EPZ24.scid. Service: rithmic_v2.trading 2024-10-07 04:52:04.585 | HD Request # 3 | Download start date-time: 2024-09-27 14:05:30.000000. File last date-time: 2024-09-27 14:05:30.342004 2024-10-07 04:52:04.585 | HD Request # 3 | Using server: rsc.rithmic.com port 50530. Use encryption. 2024-10-07 04:52:04.585 | Socket (1) | Creating socket. Using TLS 1.2. 2024-10-07 04:52:04.586 | Socket (1) | New receive buffer size: 0 2024-10-07 04:52:04.586 | Socket (1) | Connecting to IP: 216.57.156.163. 2024-10-07 04:52:04.835 | HD Request # 3 | Sending historical data logon request message. 2024-10-07 04:52:04.838 | Socket (4) | Socket gracefully closed by remote side. 2024-10-07 04:52:04.838 | Socket (4) | Closed. 2024-10-07 04:52:04.963 | Loaded depth data records for F.US.EPZ24 2024-09-27 from 2024-09-27 09:30:12.298000 to 2024-09-27 10:05:30.342000. 2024-10-07 04:52:04.965 | F.US.EPZ24 [CBV-D] 500 Volume #8 | StartDateTimeForLoadingOrderFills: 2024-09-13 00:00:00 2024-10-07 04:52:04.987 | F.US.EPZ24 [CBV-D] 500 Volume #8 | Chart data loading complete. 2024-10-07 04:52:05.149 | F.US.EPZ24 [CBV-D] 500 Volume #8 | Reloading chart. 2024-10-07 04:52:05.149 | F.US.EPZ24 [CBV-D] 500 Volume #8 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:52:05.149 | F.US.EPZ24 [CBV-D] 500 Volume #8 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:52:05.319 | File >> Disconnect selected. 2024-10-07 04:52:05.319 | DTC Client socket (0) | CloseSocket call. 2024-10-07 04:52:05.320 | Rithmic Direct - DTC | Disconnected. 2024-10-07 04:52:05.320 | Canceling queued historical data download request for F.US.EPZ24 Daily data. 2024-10-07 04:52:05.320 | Removing historical data download ID 2. 2024-10-07 04:52:05.320 | HD Request # 3 | Active download canceled. 2024-10-07 04:52:05.320 | Historical data download thread signaled to stop. 2024-10-07 04:52:05.320 | Socket (1) | CloseSocket call. 2024-10-07 04:52:05.320 | Socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-10-07 04:52:05.320 | HD Request # 3 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.EPZ24 2024-10-07 04:52:05.320 | HD Request # 3 | Completion time: 1s. 2024-10-07 04:52:05.320 | HD Request # 3 | Intraday data download complete for F.US.EPZ24. Unique request ID: 1 2024-10-07 04:52:05.320 | Removing historical data download ID 1. 2024-10-07 04:52:05.320 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2024-10-07 04:52:05.321 | 2024-10-07 04:52:05.321 | No download requests in the queue to start downloads for. 2024-10-07 04:52:05.340 | Socket (1) | Write has completed. Shutdown being performed. 2024-10-07 04:52:05.340 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-10-07 04:52:05.591 | Socket (1) | Socket gracefully closed by remote side. 2024-10-07 04:52:05.591 | Socket (1) | Closed. 2024-10-07 04:52:05.664 | F.US.EPZ24 [CBV-D] Daily #2 | Reloading chart. 2024-10-07 04:52:05.664 | F.US.EPZ24 [CBV-D] Daily #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-10-07 04:52:05.664 | F.US.EPZ24 [CBV-D] Daily #2 | There are no continuous futures contract symbols. Loading data normally. 2024-10-07 04:52:05.717 | F.US.EPZ24 [CBV-D] Daily #2 | Chart data loading complete. 2024-10-07 04:52:06.381 | F.US.EPZ24 [CBV-D] 500 Volume #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-09-23 11:16:03. Next Bar Date Time: 2024-09-23 11:10:55. Filename: F.US.EPZ24.scid 2024-10-07 04:52:07.132 | F.US.EPZ24 [CBV-D] 500 Volume #8 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2024-09-23 11:16:03. Next Bar Date Time: 2024-09-23 11:10:55. Filename: F.US.EPZ24.scid 2024-10-07 04:52:07.473 | Loading market depth data. 2024-10-07 04:52:07.770 | Loaded depth data records for F.US.EPZ24 2024-09-18 from 2024-09-18 09:30:00.000000 to 2024-09-18 10:04:25.461791. 2024-10-07 04:52:07.820 | Loaded depth data records for F.US.EPZ24 2024-09-19 from 00:00:00.000000 to 00:00:00.000000. 2024-10-07 04:52:08.761 | Loaded depth data records for F.US.EPZ24 2024-09-25 from 2024-09-25 12:56:51.812000 to 2024-09-25 17:59:59.814000. 2024-10-07 04:52:09.044 | Loading market depth data. 2024-10-07 04:52:09.328 | Loaded depth data records for F.US.EPZ24 2024-09-18 from 2024-09-18 09:30:00.000000 to 2024-09-18 10:04:25.461791. 2024-10-07 04:52:09.359 | Loaded depth data records for F.US.EPZ24 2024-09-19 from 00:00:00.000000 to 00:00:00.000000. 2024-10-07 04:52:09.789 | Loaded depth data records for F.US.EPZ24 2024-09-26 from 2024-09-26 11:04:35.622000 to 2024-09-26 15:38:44.415703. 2024-10-07 04:52:10.135 | Loaded depth data records for F.US.EPZ24 2024-09-25 from 2024-09-25 12:56:51.812000 to 2024-09-25 17:59:59.814000. 2024-10-07 04:52:10.318 | Loaded depth data records for F.US.EPZ24 2024-09-27 from 2024-09-27 09:30:12.298000 to 2024-09-27 10:05:30.342000. 2024-10-07 04:52:10.321 | F.US.EPZ24 [CBV-D] 500 Volume #1 | StartDateTimeForLoadingOrderFills: 2024-09-13 00:00:00 2024-10-07 04:52:10.343 | F.US.EPZ24 [CBV-D] 500 Volume #1 | Chart data loading complete. 2024-10-07 04:52:11.000 | Loaded depth data records for F.US.EPZ24 2024-09-26 from 2024-09-26 11:04:35.622000 to 2024-09-26 15:38:44.415703. 2024-10-07 04:52:11.429 | Loaded depth data records for F.US.EPZ24 2024-09-27 from 2024-09-27 09:30:12.298000 to 2024-09-27 10:05:30.342000. 2024-10-07 04:52:11.431 | F.US.EPZ24 [CBV-D] 500 Volume #8 | StartDateTimeForLoadingOrderFills: 2024-09-13 00:00:00 2024-10-07 04:52:11.452 | F.US.EPZ24 [CBV-D] 500 Volume #8 | Chart data loading complete. 2024-10-07 04:52:22.998 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. 2024-10-07 04:52:22.998 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (1) | New receive buffer size: 0 2024-10-07 04:52:22.998 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (1) | Connecting to IP: 216.66.0.130. 2024-10-07 04:52:24.283 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 75789 2024-10-07 04:52:24.284 | Rithmic Direct - DTC | Processed connection points. Count: 324 2024-10-07 04:52:24.528 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (1) | CloseSocket call. 2024-10-07 04:52:24.528 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (1) | Shutdown started. Waiting for graceful close. 2024-10-07 04:52:24.742 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. 2024-10-07 04:52:24.742 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (1) | Closed. 2024-10-07 04:54:00.941 | 2024-10-07 04:54:00.941 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-10-07 04:54:00.941 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2024-10-07 04:54:00.942 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2024-10-07 04:54:00.945 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-10-07 04:54:00.946 | DTC Client socket (1) | New receive buffer size: 0 2024-10-07 04:54:00.946 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-10-07 04:54:01.197 | Rithmic Direct - DTC | Network connection to server complete. 2024-10-07 04:54:01.197 | Rithmic Direct - DTC | Starting socket receive thread. 2024-10-07 04:54:01.197 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-10-07 04:54:01.197 | Rithmic Direct - DTC | Sending logon request message. 2024-10-07 04:54:01.956 | Rithmic Direct - DTC | Received logon response. 2024-10-07 04:54:01.956 | Rithmic Direct - DTC | Server Name: . 2024-10-07 04:54:01.956 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-10-07 04:54:01.956 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-10-07 04:54:01.956 | Rithmic Direct - DTC | Failed connections: 3 2024-10-07 04:54:01.956 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-10-07 04:54:01.956 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-10-07 04:54:02.045 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-10-07 04:54:02.046 | DTC Client socket (1) | CloseSocket call. 2024-10-07 04:54:02.047 | Rithmic Direct - DTC | Disconnected. 2024-10-07 04:54:02.047 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-10-07 04:54:02.047 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-10-07 04:54:02.298 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-10-07 04:54:02.298 | DTC Client socket (1) | Closed. 2024-10-07 04:54:06.040 | 2024-10-07 04:54:06.041 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2024-10-07 04:54:06.041 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2024-10-07 04:54:06.041 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2024-10-07 04:54:06.041 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-10-07 04:54:06.042 | DTC Client socket (1) | New receive buffer size: 0 2024-10-07 04:54:06.042 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-10-07 04:54:06.281 | Rithmic Direct - DTC | Network connection to server complete. 2024-10-07 04:54:06.281 | Rithmic Direct - DTC | Starting socket receive thread. 2024-10-07 04:54:06.282 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-10-07 04:54:06.282 | Rithmic Direct - DTC | Sending logon request message. 2024-10-07 04:54:07.040 | Rithmic Direct - DTC | Received logon response. 2024-10-07 04:54:07.040 | Rithmic Direct - DTC | Server Name: . 2024-10-07 04:54:07.040 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-10-07 04:54:07.040 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-10-07 04:54:07.040 | Rithmic Direct - DTC | Failed connections: 4 2024-10-07 04:54:07.040 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-10-07 04:54:07.040 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-10-07 04:54:07.063 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-10-07 04:54:07.064 | DTC Client socket (1) | CloseSocket call. 2024-10-07 04:54:07.064 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-10-07 04:54:07.064 | Rithmic Direct - DTC | Disconnected. 2024-10-07 04:54:07.064 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-10-07 04:54:07.302 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-10-07 04:54:07.302 | DTC Client socket (1) | Closed. 2024-10-07 04:54:11.007 | File >> Disconnect selected. 2024-10-07 04:54:11.007 | DTC Client socket (0) | CloseSocket call. 2024-10-07 04:54:11.008 | Rithmic Direct - DTC | Disconnected. 2024-10-07 04:54:26.050 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | Creating socket. Using TLS 1.2. 2024-10-07 04:54:26.050 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | New receive buffer size: 0 2024-10-07 04:54:26.050 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | Connecting to IP: 216.66.0.130. 2024-10-07 04:54:27.356 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 75789 2024-10-07 04:54:27.357 | Rithmic Direct - DTC | Processed connection points. Count: 324 2024-10-07 04:54:27.611 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | CloseSocket call. 2024-10-07 04:54:27.611 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | Shutdown started. Waiting for graceful close. 2024-10-07 04:54:27.826 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | Socket gracefully closed by remote side. 2024-10-07 04:54:27.826 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (1) | Closed. |
[2024-10-07 15:08:21] |
John - SC Support - Posts: 36203 |
The following is the pertinent line from your log: Rithmic Direct - DTC | Logon error received from server: permission denied
Refer to the following regarding this: Rithmic Trading Platform Service: Permission Denied Resolution Procedure For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
