Date/Time: Fri, 22 Nov 2024 07:02:37 +0000
Problem searching forum
View Count: 3031
[2013-05-08 17:47:22] |
vegasfoster - Posts: 444 |
Hi, FYI, when I search and click on a post and then click the back button to view the other search results, I am getting this page http://screencast.com/t/65qnUzna and then have to start the search all over again. It won't go back to the search results. |
[2013-05-08 18:40:45] |
Sawtooth - Posts: 4118 |
I get something similar with Firefox. See pic. |
firefox.png / V - Attached On 2013-05-08 18:39:42 UTC - Size: 19.07 KB - 644 views |
[2013-05-08 18:40:47] |
Sierra Chart - Max - Posts: 5729 |
From the screenshot: This webpage requires data that you entered earlier in order to be properly displayed. You can send this data again, but by doing so you will repeat any action this page previously performed. Press Reload to resend that data and display this page. You will have to press Reload or F5 on your keyboard to see the results. @Tom: On Firefox you will have click the "Try Again" button, to reload the search results. This is a safety mechanism that is built into browsers to avoid double sending of a form. Sierra Chart Support Date Time Of Last Edit: 2013-05-08 18:42:53
[2013-05-08 19:19:53] |
The Search Form has been updated to work better with the back button.
Sierra Chart Support |
[2013-05-13 14:45:33] |
Thanks!!!
