Date/Time: Fri, 22 Nov 2024 17:12:39 +0000
Copy Trading - Unable to remove the One Acct that has passed
View Count: 94
[2024-10-04 14:23:32] |
User115147 - Posts: 2 |
I started 1 Apex Acct first - them added 9 more. The first acct APEX-120010-03 is now just over 53,000. I want to remove from copy trading and work on the other 9 accts But under "Order Allocation to Trade Accounts" in the :Allocation Accounts List - REMOVE - it is not listing my -03 account that I want to remove. It shows -03 in "Available Accts list to Add, but the -03 acct does not show to Remove. No reason to trade the -03 obviously. I don't know what the issue is, I just want to Remove the -03 acct. Appreciate any help! Thank you so much! Gary |
[2024-10-04 17:35:42] |
John - SC Support - Posts: 36221 |
It sounds like you were using that -03 account as your main account that you were trading from. As such, you did not add it to the list of accounts to copy to, which is appropriate. Given what you state, if you do not want to trade that account any longer, then not having it in the Order Allocation list is good. Just make sure it is not the selected account on the Trade Window as well, so you do not trade it accidentally. Refer to the following: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
