Date/Time: Fri, 22 Nov 2024 16:18:11 +0000
Memory Issue: How to delete old and invalid Chartbooks
View Count: 77
[2024-10-04 12:58:54] |
Naive - Posts: 13 |
Hi, I notice I have some symbols that are no longer useful, how can I delete them? I want to delete everything about these symbols including the chartbook and the depth of the market. Also, I want to delete the expired contracts of futures, how can I do that? Thanks! |
[2024-10-04 13:37:09] |
Sierra_Chart Engineering - Posts: 17143 |
Refer to: Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency Also refer to: Chartbooks (Workspaces): Deleting a Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
