Date/Time: Fri, 22 Nov 2024 16:56:01 +0000
How to plot a price level from a specific time (Daily OHLC)
View Count: 131
[2024-10-04 01:56:34] |
User556806 - Posts: 14 |
Hi I'm currently using daily OHLC for levels. My Close is set at 5pm, but I would also like to have a level showing close price at 4pm. Is there anyway to do it? Thanks! |
[2024-10-04 17:12:47] |
John - SC Support - Posts: 36221 |
Use the "High/Low for Time Period". You can set what you use for the High and the Low, so you can use it on the Close. Refer to the following: High/Low for Time Period - Extended For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-05 03:53:56] |
Thank you! But it seems it's not working. Pls see my screen shots.
Date Time Of Last Edit: 2024-10-05 04:09:05
Attachment Deleted. |
[2024-10-07 13:45:05] |
You need to enter the "Start Time" and the "End Time" to be the same value (16:00:00). That way you will get the close for the bar at that time.
