Date/Time: Fri, 22 Nov 2024 17:03:47 +0000
UI help needed - How can i expand price on the right side.
View Count: 103
[2024-10-04 01:20:29]
User400731 - Posts: 1
I am looking UI help, How can i expand price on the right side.
imageSC_Screenshot.png / V - Attached On 2024-10-04 01:20:25 UTC - Size: 53.75 KB - 24 views
[2024-10-04 16:41:01]
ondafringe - Posts: 283
Try holding your mouse pointer over the price ladder (on the right) and then left-click-hold and drag the price ladder up and down to where you want it.
[2024-10-04 17:54:54]
John - SC Support - Posts: 36221
Refer to the following:
Working With Charts: Interactive Scaling: Compress/Expand Vertical Scale, Move Chart Up and Down
General Settings Window: Interactive Scale Range Movement Adjust Direction (Global Settings >> General Settings >> Charts >> Charts)
