Date/Time: Fri, 22 Nov 2024 16:09:34 +0000
Delayed Data Feed
View Count: 119
[2024-10-03 19:26:24]
Hopsing - Posts: 3
I've been receiving regular exchange feeds for a few weeks now. Magically today I'm receiving delayed data feeds. Can you help a brother out?
[2024-10-03 21:06:41]
John - SC Support - Posts: 36217
You are not setup to get any data from us - meaning that you do not have any exchanges active with our Denali Exchange Data Feed. You have also never been getting any real-time data from our Denali Exchange Data Feed.
If you were getting real-time data, then that would have been through your trading service. What trading service are you using? Are you using a different service now than you were previously?
[2024-10-03 21:20:46]
Hopsing - Posts: 3
Thanks for the reply. I'm using AMP. When I set Sierra up, I hooked it up with data nasdaq total view as well as package 12. But I can understand AMP taking over the data feed. The delayed data, is this an AMP issue then?
[2024-10-04 00:12:01]
This not an AMP issue. We do not see your having setup the NASDAQ TotalView exchange with us in order to get real-time data. So you should not have been getting any real-time data, at least not from us.
We see that you have activated the "CME with Market Depth for Non-Professional Trading Accounts. You should be getting real-time data for the CME exchange at this time.
If you are still having an issue, then let us know what it is.
[2024-10-04 00:34:37]
Hopsing - Posts: 3
Thanks John. I actually reactivated that Denali feed. I saw under "Deactivated Recurring Services" that the feed was deactivated on September 30th. Thought it would renew but I guess not. Thanks for your help though.
[2024-10-04 13:09:07]
Sorry, we must have missed that exchange being active. You must not have had enough funds in your account for the renewal at that time.
