Date/Time: Fri, 22 Nov 2024 15:40:58 +0000
[User Discussion] - Serious Problem with TPO charts
View Count: 109
[2024-10-03 18:29:15] |
User293951 - Posts: 15 |
I have two PCs working. Same chartbook. One PC is running version 2671. This is the older version. It runs correctly The second PC is running version 2679. This is a newer, updated version, obviously. On the older version the TPO chart (Market Profile) appears correctly. With different color for the evening session(s). I am using multiple daily sessions. On the newer version the evening session appears with the same color as the morning session. Both PCs are using exactly the same chartbook. No alternations at all. Please do something with this issue that has appeared in the latest version, because I always mess up the sessions. I have submitted the pictures and the chartbook. |
IMG_20241003_154916862.jpg / V - Attached On 2024-10-03 18:27:10 UTC - Size: 181.19 KB - 40 views Rithmic_Apex_1_MPs_1min_Split-Profiles_from left.Cht - Attached On 2024-10-03 18:28:33 UTC - Size: 18.45 KB - 60 views Attachment Deleted. |
[2024-10-03 18:31:21] |
Repost the other picture because it was deleted during the upload for no reason
IMG_20241003_154907331.jpg / V - Attached On 2024-10-03 18:30:50 UTC - Size: 195.56 KB - 37 views |
[2024-10-03 18:58:28] |
John - SC Support - Posts: 36216 |
Update to the current release, there was a change to how the Value Area coloring was handled for the evening session, and in that process the Evening Session coloring within a single TPO was changed by accident. This has been corrected in the current release. Follow these instructions to update: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
