Date/Time: Wed, 27 Nov 2024 12:34:46 +0000
User rename of studies
View Count: 1118
[2014-09-04 19:23:27] |
User57562 - Posts: 98 |
It would help customization if user could rename studies, e.g., for versions and multiple copies.
[2014-09-04 20:56:19] |
The name of the study can be changed through the Short Name setting in the Study Settings window for the study. This only applies to that instance of the study. However, you can change default study settings: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#CustomDefaultStudySettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-04 21:06:14
