Date/Time: Fri, 22 Nov 2024 16:01:31 +0000
ver. 2686 NUMBERS BAR (diagonal comparison up not functional)
View Count: 166
[2024-10-03 15:53:04]
blt - Posts: 31
...fyi gentlemen
...in newest prerelease (ver.2686) NUMBERS BAR option "Based on Diagonal Side AskVolBidVol Percentage" doesn't show Up (Ask side); Bid side works [Column 1 Text Coloring Method]
...everything works when you go back to current ver.
...I will test the rest of versions
...thank you and do not get mad if I am wrong
[2024-10-03 16:13:50]
blt - Posts: 31
...just tested how far back that will work
...ver. 2682 is ok but when you try to open studies clicking right on chart dialog box comes up blank !!!
...will go back to current 2686 waiting for correction
...thank you again
[2024-10-03 17:12:54]
John - SC Support - Posts: 36217
There is no correction - there were some changes to the Numbers Bars for how to control how the Diagonal comparisons are performed. Specifically, the Input for "Allow Diagonal Bid Ask Compares" has been broken into two different controls. Refer to the following and the item below it:
Numbers Bars: Enable Diagonal Bid/Ask Compare with No Data at High/Low
[2024-10-03 17:58:24]
blt - Posts: 31
...conclusion
...for some reason option "Column 1 Text Coloring Method" was wrongly set
...after bringing that to "Based on Separate Diagonal AskVolBidVol Percentage" all works perfect
...thank you
...were you able to demonstrate blank dialog box when you right click on chart in previous versions (it that has any value for you guys being older versions)
[2024-10-03 18:52:03]
Yes, there was an issue with the right-click options showing in certain versions. This has all been resolved in the current release - v 2686.
