Date/Time: Fri, 22 Nov 2024 16:18:37 +0000
Chart DOM - Different size between right and left click of the mouse
View Count: 90
[2024-10-03 15:24:26]
User325448 - Posts: 7
I am trying to find settings to enable different order sizes for left and right mouse clicks. For example:
Left click for a normal size pre-set.
Right click for multiples of the pre-set size.
For instance:
Left click buy above the current price - 1lot
Right click buy above the current price - 1lot * multiple.
Could someone help me locate these settings or confirm if this functionality exists?
[2024-10-03 16:49:33]
John - SC Support - Posts: 36220
This functionality does not exist in the built-in tools for Sierra Chart. You could see if there is a 3rd party tool that does this, or program it yourself (or have it programmed). Refer to the following:
Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
