Date/Time: Fri, 22 Nov 2024 11:14:52 +0000
Market Depth levels
View Count: 141
[2024-10-03 14:47:32]
User731023 - Posts: 138
I have a column on chart for Market Depth levels. I only show the totals which is what I want.
The rest are same color so I do not see them.
I had to put Sierra on a different computer because of a problem with the one I was using.
Total bummer because I have to redo all my old settings.
I only want 10 levels up and down on this column but can not change it. Or should
I say don't remember how. I go to Chart then Market depth and put 10 in Max levels
to no avail. Help please.
attachmentChart.bmp - Attached On 2024-10-03 14:46:12 UTC - Size: 5.13 MB - 66 views
[2024-10-03 15:07:40]
John - SC Support - Posts: 36203
"Chart >> Chart Settings >> Market Depth >> Maximum Market Depth Levels" is the correct setting to control the number of levels in a chart. This setting only affects that one chart, so make sure you are setting it for the correct chart. Refer to the following:
Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu)
Refer to the following for how to transfer your settings and chartbooks from one system another - assuming you are able to access the drive on the old system:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
[2024-10-07 19:10:10]
The column I am pointing to is the total of Bid/Ask staking and pulling. Only the total
with the rest the same color so I do not see it/them.
Easier to just watch the totals change.
Anyway I found out that you also have to designate the number of levels for this as well.
(See snapshot) I was not clear on the original post that the column was bid/ask stacking.
Wanted to post a follow up on it to clarify.
attachmentChart.bmp - Attached On 2024-10-07 19:09:22 UTC - Size: 1.95 MB - 46 views
