Date/Time: Fri, 22 Nov 2024 16:10:17 +0000
[User Discussion] - In this era of multiple prop firms, is there a way to trade multiple firms?
View Count: 181
[2024-10-03 00:20:07]
jackbravo - Posts: 69
I have a personal account (Teton) as well as accounts with several different prop firms (through Rithmic). Current, I'm using multiple instances of Sierra, one for each set of accounts. But it requires placing trades manually in different instances, which becomes difficult during the trading day and error-prone. I'm currently using the Order Allocation feature to trade multiple accounts under the same Rithmic login. Is there a way to be able to the trade copier across my personal account and across Rithmic logins , each with multiple accounts? If not, would SC be willing to create that functionality for its users? It would be helpful in the current era.
Thank you.
[2024-10-03 02:09:14]
gcUserStudies - Posts: 106
This trade copier will do what you are wanting.
https://www.simplesystemtrading.com/local-trade-copier/
[2024-10-03 14:01:21]
Someone used it and said it can get out of sync. ANy experience with that?
Would be prob more stable to have native multi-broker support
[2024-10-03 15:28:28]
I no longer use it. But I gave it a good test run a while back for about a month and didn't have any issues. They key with it like anything else is to just have trade positions windows up for each broker so you can monitor trade status etc... and ensure all fills occur and positions are closed as expected. I think there is a free trial so you could test it out.
