Date/Time: Mon, 28 Oct 2024 08:57:43 +0000
[Programming Help] - number bar alert condition if possible
View Count: 90
[2024-10-02 12:03:12] |
User602649 - Posts: 3 |
trust all is well, is there any coder in here i could get some advise from i am trying to create an alert condition for then number bar chart, when a down candle has positive (blue delta) on top of it but unfortunately the range columns does not have a sub graph to use, have you done something like this before thanks |
Attachment Deleted. |
[2024-10-02 14:17:09] |
John - SC Support - Posts: 35538 |
A Down candle is defined as one where the Close is lower than the High. So the Alert condition for this is the following: =C < O In terms of the blue bar at the top, what we need more information for is what do you mean by the "top"? How are you defining this? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
