Date/Time: Fri, 22 Nov 2024 16:05:11 +0000
Time and Sales Attach/Detach
View Count: 185
[2024-10-02 10:19:07] |
User131975 - Posts: 78 |
I have a problem and that is that the Time and Sales list is always at the top. Is it not possible that the Time and Sales list is there like a normal chart? At the moment, the Time and Sales list is always on top and when I detach it, it is immediately behind the Sierrachart software as soon as I click on something.
[2024-10-02 10:22:48] |
The problem is that I often make a chart in full screen mode to analyze it but then the Time and Sales list is basically “Always on Top” although I have not activated it.
[2024-10-02 14:05:04] |
John - SC Support - Posts: 36217 |
The Time and Sales is "Always on Top" when it is attached. If you detach it, then you have the option to set "Always on Top" to be enabled or disabled. If it is disabled, then whenever another window is selected, that will come forward and be above the Time and Sales.
[2024-10-02 15:52:46] |
Yes, that's exactly how it is for me. But is there no way to attach this Time and Sales list without “Always on Top”? At the moment I have to make the Sierrachart software in window mode and then the Time and Sales next to the window because as soon as I make another window in the software to full screen the Time and Sales list overlaps this full screen window because of the “Always on Top”. I have posted a screenshot so you can see what I mean Date Time Of Last Edit: 2024-10-02 15:53:12
Fullscreen Chart with Time and Sales.png / V - Attached On 2024-10-02 15:52:40 UTC - Size: 292.13 KB - 35 views |
[2024-10-02 19:17:31] |
There is no method for attached the Time And Sales to a chart or to the main Sierra Chart window. What you are seeing is the functionality of that window.
[2024-10-02 19:41:15] |
How do we use sierrachart then? All windows individually? There must be a reason why you can't attach the Time and Sales list. Date Time Of Last Edit: 2024-10-02 19:43:14
[2024-10-02 19:47:29] |
Can this be programmed, please? I am a programmer myself and they would just have to treat the window like the others. As it is now, it is unfortunately not good with the Time and Sales list.
Date Time Of Last Edit: 2024-10-02 19:47:43
[2024-10-02 19:50:36] |
We take all requests, but we can not say when we would get to any item in particular.
[2024-10-02 21:56:35] |
Thank you very much. It would be really great if this was implemented. It wouldn't really be an effort. Is a dark mode also planned for sierrachart? I think if that was implemented then sierrachart would go through the roof :)
