Date/Time: Mon, 28 Oct 2024 08:57:43 +0000
Fills showing wrong.
View Count: 72
[2024-10-02 09:28:36] |
User945394 - Posts: 4 |
I am experiencing an issue with my chart display after a recent update. The fills on my chart are showing wired lines, and it appears to incorrectly display that I have an open position from the day before. I have attached a screenshot for reference, where I opened two positions, but one of the position lines is showing incorrectly. I haven’t changed any settings, just performed a regular update. Could you please assist me in resolving this? Thank you for your help. Best regards, Blasius |
Screenshot 2024-10-01 at 20.28.57.png / V - Attached On 2024-10-02 09:27:48 UTC - Size: 980.05 KB - 24 views Attachment Deleted. Screenshot 2024-10-02 at 11.57.43.png / V - Attached On 2024-10-02 09:28:12 UTC - Size: 799.39 KB - 25 views |
[2024-10-02 14:02:40] |
John - SC Support - Posts: 35538 |
Refer to the information at the following link: Help With Daily Profit/Loss Value: Simplified Steps to Solve Incorrect Daily Profit/Loss For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-02 18:11:45] |
Sierra_Chart Engineering - Posts: 16755 |
Also refer to: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
