Date/Time: Wed, 23 Sep 2026 02:56:37 +0000
[Programming Help] - ASCIL: 'optional' Index parameter; sc.AutoLoop
View Count: 623
[2024-10-02 02:09:51]
User379249 - Posts: 9
Trying to make a custom Correlation study and using scsf_CorrelationCoefficient as paradigm. That study calls function GetCorrelationCoefficient as found in SCStudyFunctions. I created a similar function to do Kendall Tau correlation through much cut and paste. My scsf_KendallTauCoefficient calls my GetKendallTauCoefficient but my code does not compile ("..too few arguments to function.."). My reading clearly indicates its related to the optional 'int Index' parameter and the sc.AutoLoop = 1 setting. Perhaps I am not enabled to compile such autolooping functions which allow for the use of the Index in the function code block despite not passing the Index in. Flummoxed. I am attaching my .cpp file. (I have function and study in one file)
Thanks in advance for your help.
attachmentpost to SC Support.txt - Attached On 2024-10-02 02:09:05 UTC - Size: 2.74 KB - 315 views
[2024-10-02 08:43:05]
User431178 - Posts: 907
You need to pass in the index parameter, you cannot omit function parameters (unless they are declared with a default value in your declaration/signature).
GetKendallTauCorrelationCoefficient(Array1, Array2, sc.Index, Input_Length.GetInt());
The "indexless" version of scsf_CorrelationCoefficient is an overload with a different signature, it has no index parameter, but instead uses the sc.Index member variable directly.
Take a look in file "sierrachart.h" and you will see what is happening.
[2024-10-02 12:46:55]
Thanks for the rapid feedback. It's really appreciated.
The clarification is appreciated. I knew something was clearly wrong but was not sure exactly given the AutoLoop condition.
To be clear, I will pass in the Index parameter. I am not sure how this looks exactly as I am just trying to emulate the CorrelationCoefficient code which does not pass that in.
Also, if I am passing in the variable is the sc.AutoLoop=1 statement still correct and necessary?
I did add the parameter as "(..... , sc.Index, ...)" and kept sc.AutoLoop=1 and the study appears to work just fine. Happy to close this ticket but also happy to receive any comment you might have.
Paul
