Date/Time: Mon, 28 Oct 2024 08:57:44 +0000
data feed --- options trading on futures
View Count: 79
[2024-10-01 18:10:28] |
winner - Posts: 4 |
Hi there, I would like to trade options on ES. May I ask what I need to do? Look forward to hearing from you. Thank you.
[2024-10-01 18:14:12] |
John - SC Support - Posts: 35538 |
It looks like you are using our Teton Order Routing service, and unfortunately, this service does not support trading Options. You could always use a different account for trading Options. If you do, then refer to the following for how to install a second Sierra Chart that you would connect to that account: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart In order to view the data for Options, refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Futures Options For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
