Date/Time: Mon, 28 Oct 2024 08:57:45 +0000
Indicator Alerts
View Count: 69
[2024-10-01 17:34:08] |
User169418 - Posts: 1 |
Hello, I started using the "Bill Williams Alligator" indicator. I would like so set an Alert that informs me, when SG1 crosses SG3 or vice versa. Could you please tell me, how I can achieve this? Also, where can I change the sound of an Alert? Thank you! Best |
[2024-10-01 17:36:37] |
John - SC Support - Posts: 35538 |
The formula for an alert for this would be the following: =CROSSOVER(SG1, SG3) You would need to enter the alert on the settings window for that specific study. Otherwise, you would also need to reference the ID of the study. Refer to the following and the section below it: Study/Chart Alerts And Scanning: Referencing Study Subgraphs Refer to the following for how to change the settings for an alert (including the sound): General Settings Window: Configuring Alert Number Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
