Date/Time: Mon, 28 Oct 2024 08:57:44 +0000
No real time data for SPY
View Count: 65
[2024-10-01 17:17:23] |
midwestTrader - Posts: 2 |
Hello, All the sudden SPY stopped showing data on my chart/DOM. When I open or try connecting my charts it shows the data (and past data) up to the point I open/connect, however there is no real time data displaying. I'm using symbol SPY-NQTV. This issue is actually with all symbols (i.e. TSLA-NQTV) on this chart and DOM not just SPY. I have the Service Package 12, Nasdaq TotalView. Not sure why my charts aren't providing data. Any suggestions on things I can try to fix this issue? thanks. |
[2024-10-01 20:04:25] |
John - SC Support - Posts: 35538 |
If you are still having an issue, then please get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
