Date/Time: Mon, 28 Oct 2024 08:57:45 +0000
Data is delayed
View Count: 62
[2024-10-01 15:36:19] |
User443396 - Posts: 6 |
How do I get current data?
[2024-10-01 15:37:39] |
John - SC Support - Posts: 35538 |
Everything on your account looks good so you should be getting real-time data for The CME Group and U.S. Equities. If you are still having a problem with data from these exchanges then we would need to see your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
