Date/Time: Sun, 20 Sep 2026 04:22:57 +0000
Stock split not display properly for SMCI
View Count: 510
| [2024-10-01 12:52:00] |
| UserAR - Posts: 99 |
I have already done 'delete all data' and download for both historical and real time charts and they are not updating past data for the split. Can you please check? Thanks
| [2024-10-01 21:46:10] |
| Sierra_Chart Engineering - Posts: 24894 |
If the split occurred today, this will be adjusted this evening. Refer to: US Stock/Equities Consolidated Tape Data Feed: Stock Split Adjustments Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
