Date/Time: Fri, 25 Sep 2026 15:56:37 +0000
Problem With Numbers Bars Chart
View Count: 630
| [2024-10-01 07:20:18] |
| TraderBake - Posts: 63 |
In Version 2679 I had no Chart Shortcut Menu, so I Downloaded Pre release 2686. Now I have some black bricks in my Footprint Chart on the traded Volume, so I am not able to read the numbers. It only appears on some price levels. Never had this before |
Attachment Deleted. |
| [2024-10-01 14:49:01] |
| John - SC Support - Posts: 48013 |
With the latest version there are a couple of changes to how you control comparisons with no values at the high/low and a separate item for diagonal comparisons with zero values. Make sure these are set as you need them. Refer to the following and the item below it: Numbers Bars: Enable Diagonal Bid/Ask Compare with No Data at High/Low For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-10-01 19:27:24] |
Thank you, everything is fine again.
