Date/Time: Fri, 22 Nov 2024 16:21:21 +0000
Copy chart image
View Count: 90
[2024-10-01 06:52:18] |
arruga - Posts: 253 |
Why can't I copy the chart image? It's not letting me https://www.sierrachart.com/image.php?Image=172776547177.png |
[2024-10-01 14:45:19] |
John - SC Support - Posts: 36220 |
You attached an image that looks perfectly fine. What exactly is the issue you are having?
[2024-10-03 09:31:29] |
The image you saw is the link I got via 'Upload chart' What I mean is when I right click on the chart and 'Copy Chart Image'... it fails.. don't get the image |
[2024-10-03 13:59:36] |
Sierra_Chart Engineering - Posts: 17143 |
Update Sierra Chart to the latest prerelease version to resolve. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
