Date/Time: Fri, 22 Nov 2024 15:50:32 +0000
bitcoin payment newbie
View Count: 99
[2024-09-30 23:34:10] |
User289654 - Posts: 1 |
Hi, I have a kraken account and as far as i know,the payment amount if using bitcoin is much larger than usd$50.How do i pay with bitcoin? Will i need to send the bitcoin to another exchange? If so, would anyone have any suggestions of which one? I also have no idea what is bitcoin (direct),does it involve an exchange or does it by pass the blockchain somehow?? Thanks and regards |
[2024-10-01 06:07:39] |
Sierra_Chart Engineering - Posts: 17143 |
Our strong recommendation is not keeping your crypto currency at an exchange, but use your own "wallet" to hold your crypto. You do not have to bother with any exchanges. Have a look at: https://trezor.io/ https://bitcoincore.org/ You do not have to be concerned with any minimum payments when you are in direct control of your crypto. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
