Date/Time: Fri, 22 Nov 2024 16:10:52 +0000
FLEXY TRADE PROP FIRM
View Count: 140
[2024-09-30 21:29:17] |
RAMON ESPARZA - Posts: 1 |
GREETINGS TEAM, I NEED TO CONNECT THIS PROP FIRM SUPPORTED BY YOU, BUT THEY DO NOT HAVE A SET OF INSTRUCTIONS TO CONNECT WITH YOU. I ALREADY ACKNOLEDGE ALL DOCUMENTS AND CONDITIONS WITH RITHMIC TRADER PRO. I NEED TO KNOW WHICH THE SERVER TO USE. PLEASE GUIDE ME.
[2024-09-30 21:30:15] |
John - SC Support - Posts: 36217 |
The general instructions to connect to Rithmic from Sierra Chart are at the following link: Rithmic Trading Platform Service: Setup Instructions As to the particular Server you need to select, we can not say. You need to ask the Prop Firm you are working with for this information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
