Date/Time: Fri, 22 Nov 2024 15:48:16 +0000
Trailing Stop
View Count: 96
[2024-09-30 20:56:22]
SafSaf - Posts: 89
hi, pls see attached. these are my settings for a trailing stop i'm experimenting with. it's working but i want to be able to move the stop, however, when i try it just moves back to it's original position. what am i doing wrong please?
imageScreenshot 2024-09-30 055840.png / V - Attached On 2024-09-30 20:56:15 UTC - Size: 20.73 KB - 23 views
[2024-09-30 21:04:10]
John - SC Support - Posts: 36217
For one thing, you have competing issues with your Stop. You have it as both a Trailing Stop and you have a "Move to Breakeven" set for it. If you do not want it to trail until the breakeven occurs, then set the order type to be a "Triggered Trailing Stop" and set the trigger to be the same as the Move to Breakeven. Refer to the following:
Order Types: Triggered Trailing Stop
But, you should be able to modify the Stop.
When you have this occur, open your "Trade >> Trade Service Log" and post the information from that log to this thread for us to take a look. Follow these instructions to do this:
Support Board Posting Information: Providing Lines From Trade Service Log
