Date/Time: Fri, 22 Nov 2024 16:29:38 +0000
LVT INDICATOR vs. TIME&SALES
View Count: 131
[2024-09-30 16:11:46] |
blt - Posts: 31 |
...hi there ...this is situation ... ...one chart has LVT ind. filtering trades >=5 ...the same chart has T&S filtering trades >=5 ... ...VERY often there is a missed trade not shown in T&S (if LVT shows sequence of filtered trades exp. 5 8 5 5 10 7...T&S will show 5 5 5 7 -missing 8 and 10) ... ...I think you would be able to easily test that ...this doesn't bother me too much although your beyond perfect DENALI feed demands the same perfection to the rest ... ...(my trading machine is superb as well as my wired connection and proximity of Aurora Data Center; using 7 instances on 7 monitors; everything else in SC is as PERFECT as I wished for in my case) ...do not break sweat about this-I can live with it ... ...all the best Leonardo |
[2024-09-30 19:36:17] |
John - SC Support - Posts: 36221 |
The Large Volume Trade Indicator does not show every individual trade. It is, however, a compilation of the trades that are larger than the set volume at that price level for the bar. Whereas, the Time and Sales gives every individual trade. So these items will not line up as you expressed it above. We can not explain the particular numbers you gave above, but we are not sure if those are real numbers or just an example. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-30 20:05:13] |
blt - Posts: 31 |
...it was an example ...does it mean that TIME & SALE is showing what's really trading and it is 100% accurate (I am visually following those trades and making decisions) ... ...allow me to praise you a bit ... ...your DENALI/TETON is absolutely phenomenal piece of technology ...lightness of SIERRA CHART on CPU is unheard of and ...SUPPORT is THE VERY BEST I had an experience with in any domain...bravo and thank you |
[2024-09-30 22:29:02] |
Yes, the Time and Sales is showing 100% accurate. This is also true for the rest of Sierra Chart. You just need to understand what underlies certain information, such as the Large Volume Trade Indicator. And thank you for the kind words. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
