Date/Time: Fri, 22 Nov 2024 15:49:12 +0000
Control bar overlap Trade Window
View Count: 70
[2024-09-30 15:23:32] |
User474110 - Posts: 7 |
Hello, is there a way to fix the fact that the control bar (arrow 1 in attached image) overlap the trade window on chart (arrow 2 in image). The issue is that if I select the combo box of for the trade window to change the configuration, it messed up and interpret the click as it was on the control bar. TY EB |
Screenshot 2024-09-30 111803.png / V - Attached On 2024-09-30 15:20:47 UTC - Size: 62.9 KB - 23 views |
[2024-09-30 18:53:40] |
John - SC Support - Posts: 36217 |
We can not reproduce what you are seeing. It should not be occurring. First, update to the latest pre-release and see if you are continuing to have the same issue. Follow these instructions to update: Software Download: Fast Update If you continue to have a problem after the update, then detach the Trade Window and close it, then open it again attached to the chart. If that still does not fix it, then we would need to see your chartbook to see if we can reproduce the issue. Get us the chartbook by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
