Date/Time: Fri, 22 Nov 2024 17:59:35 +0000
Edit/manage options on Horizontal lines missing since latest update!
View Count: 88
[2024-09-28 22:43:48] |
J DIDDY - Posts: 126 |
HI Support When I Left Click to 'edit/manage options' on Horizontal lines they are missing and all I now get is the configuration menu - since the latest update! Will you be re-adding these options back again??? Please see screenshot attached. Thx |
SC Issue.jpg / V - Attached On 2024-09-28 22:39:12 UTC - Size: 134.52 KB - 29 views Attachment Deleted. |
[2024-09-29 04:00:29] |
Sierra_Chart Engineering - Posts: 17145 |
This issue is now resolved in prerelease version 2685. Update with Help >> Download Release. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
