Date/Time: Fri, 22 Nov 2024 17:49:15 +0000
Dashed line on studies is showing as a solid line when OpenGL setting is turned on.
View Count: 96
[2024-09-28 20:07:32]
moraha - Posts: 2
Pretty frustrating issue I can't seem to figure out. With OpenGL turned on, dashed lines show as solid unless VERY zoomed in. I turned OpenGL off and restarted SC, and that fixed the problem. I do not want OpenGL turned off though to be able to have the line work properly. Is there a fix for this?
[2024-09-29 01:41:38]
Sierra_Chart Engineering - Posts: 17145
This is just how this is. It is not something we can help with.
