Date/Time: Fri, 22 Nov 2024 15:48:23 +0000
data re-Loading after backtest NQ
View Count: 75
[2024-09-28 18:39:49] |
User725043 - Posts: 35 |
Today, on one of the instances used for Bar Based Backtest, multiyear, continuous contract, on an NQ intraday chart, after the test, the data does a complete reload. Tried the same studies/study collection/settings on another instance and does not reload the data on that instance after the backtest. Only change from yesterday was the Date Range on the file was changed this morning to include yesterday's data 2024-09-27. Thought maybe it's a corrupt file download, so deleted the last two NQ contracts using Edit > Delete All Data and Download. Did Global Settings > Symbol Settings > Update from Server. (Use Custom Symbol Settings Values is unchecked). Still reloads all contracts' data after the backtest. What other steps are there to resolve? |
[2024-09-30 22:37:42] |
Sierra_Chart Engineering - Posts: 17143 |
Are you able to reproduce this issue, when you remove all studies from the chart? We wonder if there is a particular study causing the problem. We see no reason why the chart reload would happened. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-09-30 22:37:58
