Date/Time: Fri, 22 Nov 2024 16:25:03 +0000
Denali Data Feed
View Count: 184
[2024-09-28 15:16:03] |
Deltareversal - Posts: 45 |
Kindly what should I do to see the Options (in particular SPXW) ? Denali Exchange Data Feed: Using Denali Futures Options Data with Trading Service These don't appear in my list Thx Antonio |
[2024-09-28 16:09:54] |
Sierra_Chart Engineering - Posts: 17143 |
Are those futures options? Or equity options? Or index options?
[2024-09-28 16:19:34] |
Index Options Thx Antonio |
[2024-09-28 21:52:13] |
John - SC Support - Posts: 36220 |
We do not have data for options for Indices.
[2024-09-29 10:33:59] |
Do you have futures options on Denali?
[2024-09-30 13:43:19] |
Yes, we have options data for The CME Group futures.
[2024-09-30 14:15:06] |
What do I have to do to insert them?
[2024-09-30 18:35:52] |
Follow these instructions: Real-Time Exchange Data Feeds Available From Sierra Chart: Futures Options For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
