Date/Time: Fri, 22 Nov 2024 17:50:00 +0000
Trade Definitions not working
View Count: 78
[2024-09-28 08:35:16] |
_Dzippy - Posts: 2 |
In the trade window, I have applied single, 2,3 etc contracts, each with a S/L and profit taking and each is saved with its own name. However, when I buy/sell, bid/ask, market, etc, they are not applied on opening. It only works on right clicking on the renken chart and applying the trade from there. Please advise. |
[2024-09-28 21:48:59] |
John - SC Support - Posts: 36222 |
Keep in mind each Trade Window is associated with a specific chart and each one is independent (unless you have them linked). So if you are placing a trade from one chart and not getting the attached orders, but you do get the attached orders on another chart, then you need to look at the Trade Window for the chart where you have the issue and make sure the option for "Use Attached Orders" is enabled. Refer to the following: Basic Trading and the Trade Window: Each Trade Window is Completely Independent from Others For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
