Date/Time: Fri, 22 Nov 2024 18:22:07 +0000
AutoSnap Sensitivity
View Count: 90
[2024-09-27 19:46:26] |
User749040 - Posts: 37 |
Hello SC team, so in the Tool Settings there is an option to lower the sensitivity for the AutoSnap, however it's for all tools. Is it possible to add an exclusion to this on certain tools? For example I don't like the calculator tool always snapping to price. That can be done either by adding an exclusion option or how TradingView does it and that's by holding "CTRL" you disable/enable the AutoSnap. Thank you. |
[2024-09-28 00:25:02] |
John - SC Support - Posts: 36222 |
You can setup a Control Bar button to enable/disable auto-snapping. Refer to the following: Chart Drawing Tools: Automatic Snapping on Creation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
