Date/Time: Fri, 22 Nov 2024 18:15:33 +0000
chart issue
View Count: 159
[2024-09-27 14:59:01] |
User686430 - Posts: 2 |
https://www.sierrachart.com/image.php?Image=1727422195517.png Good day, how can i fix that issue as visible on the screenshot Regards |
[2024-09-27 15:00:28] |
John - SC Support - Posts: 36222 |
We have no idea what the issue is that you are trying to point out in the image. You need to give us specific information on what you feel is not correct.
[2024-09-27 15:25:42] |
When i right klick into the chart , the windows which opened up is empty, unfortunately the window does not show on the image. I have run the newest version. How can i restore the tool in that window, i cant draw any lines or erase. I hope you can understand the issue Regards Frank |
[2024-09-27 15:29:37] |
If that right-click shortcut window is not showing, or is showing blank, then that indicates a problem with the resources on your computer. Restart your computer and make sure you limit the amount of other programs that you are running when using Sierra Chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
