Date/Time: Fri, 22 Nov 2024 17:53:44 +0000
change entry and exit order of a position
View Count: 95
[2024-09-27 14:37:03]
SafSaf - Posts: 89
alright lads, i can't find the info anywhere else so let's give you a go; when i place a market buy order then a little while later i place an additional one, i'm finding when i close one of the positions, sierra charts closes the very first order first. can i change it so it closes the second order first and lets the first one run?
[2024-09-27 15:14:22]
John - SC Support - Posts: 36222
Refer to the following:
Chart Settings: Use Last In First Out Fill Matching (Chart >> Chart Settings >> Trading menu)
