Date/Time: Fri, 22 Nov 2024 17:48:53 +0000
Export Trade Activity Log
View Count: 95
[2024-09-27 08:20:55]
nicktrader - Posts: 709
I would like to revise the “Note” field from the “Trade Activity Log” (TAL) to get optimized trade statistics.
It is possible with “Edit Trade Activity Entry”, but it is very tedious and time-consuming.
However, there is also an “Export” option. I could imagine exporting the “TAL” of the last 3 months and editing it in “Excel”. And later import it back again.
My basic question now is whether this is possible and if so, what should be taken into account? Or is there a different way?
Many thanks.
[2024-09-27 13:56:07]
John - SC Support - Posts: 36222
You can do what you are suggesting, the things to keep in mind are the following:
- The data is tab-delimited, so you need to ensure you save it out in the same way.
- When you import the new fills, they will not overwrite the old ones. You will need to delete the old ones after you import the newly changed fills.
