Date/Time: Wed, 27 Nov 2024 12:24:50 +0000
New to sierra Please HELP
View Count: 876
[2014-09-04 12:20:03] |
User15378 - Posts: 45 |
Hi there, i am looking to open up a new sierra chart account. i have a few questions: 1-I want option where i can have delta & the foot print bars- is that the subscription for 40$? Or does delta come with all subscriptions? if i dont want foot print is the 27$ ok and does it include value areas and POC? 2-Can i bring indicators into Sierra? if so what kind of file must it be? 3-With subscribing do i get a data feed and everything i need and can get started straight away? i only want to use it as a chart and enter on my mt4 broker? will this be fine? (wont be entering on sierra) Which data do you reccomend? (Sierra Chart Real Time and Historical Forex and CFD Data Service) 4-What is the whole deal with " pricing before discount"? 5-Is there a live chat if i have some issues or questions when setting up my charts? 6- can i have the same account running on 2 different pcs? ie one at home and work at the same time? Thank you very much appreciate the help as i have never been off a mt4 chart and this is all new territory. Nic Labuschagne P>S if this is not where i find this info someone please advise me where to go Date Time Of Last Edit: 2014-09-04 13:35:24
[2014-09-04 17:57:55] |
1. We do not know what is meant by Delta. This is too vague of a term. If you want to use the Sierra Chart Numbers Bars feature: https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php Then this is included with Sierra Chart service package 5. Were you interested Volume Value Area and Point of Control or based upon TPOs? 2. Yes. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_DLLUsage.html 3. If you require the Sierra Chart Forex Data Feed: Sierra Chart Real Time and Historical Forex and CFD Data Service Then this is included with all service packages. 4. Refer to: Description of Service Packages and Pricing 5. No, we do not provide a live chat. We recommend using this Support Board. 6. Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-04 17:58:59
