Date/Time: Fri, 22 Nov 2024 21:12:44 +0000
Order Fills from another SIM account
View Count: 92
[2024-09-26 20:38:46] |
User818481 - Posts: 4 |
The 2 charts on the screen are linked and currently in chart replay. You can see on the top left, "Sim1" account. On the top left of the chart on the right, you can see "Sim2". How do I get all my charts to align with Sim 2? Thank you |
Screenshot 2024-09-26 143926.png / V - Attached On 2024-09-26 20:38:42 UTC - Size: 106.31 KB - 23 views |
[2024-09-26 21:24:18] |
John - SC Support - Posts: 36236 |
Each chart has its own Trade Window which is where the specific account is defined for that chart. Refer to the following: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) You can change each chart to have the same account. Or, if you change between accounts often, you can consider setting up the linking between charts for the Trade Window. Just keep in mind with Linking, it is everything in the Trade Window that is linked, not just the account. Refer to the following: Chart Settings: Chart Linking >> Trade Window (Chart >> Chart Settings >> Linking menu) If you never use the Sim2 (or any other Simulation Accounts) then a simple solution is to set your system to only have 1 simulation account. Refer to the following: Global Trade Settings Windows: Number of Simulation Accounts (Global Settings >> General Trade Settings >> General) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
