Date/Time: Fri, 22 Nov 2024 21:21:55 +0000
Key Shortcuts not working after latest update!
View Count: 138
[2024-09-26 20:26:38]
J DIDDY - Posts: 126
Hi Support
ALL Key Shortcuts not working after latest update!
Not even the generic SC ones like 'F6 - Studies'
I'm on a mac, but the SC generic ones and the ones I programmed in Settings/ Customise Key shortcutswere working fine before this latest update roughly 2 days ago!
Are you going to update this bug?? Its impossible to use without these!
Thx
[2024-09-26 21:04:34]
I just opened Shortcuts and saw that you have amended them all - so that fixes that issue except the Menu's still have the old shortcuts listed eg, 'F6' (Studies) which now has the shortcut of 'Alt F6', so you can see the confusion!
Thx
Date Time Of Last Edit: 2024-09-26 23:39:53
[2024-09-26 23:57:56]
Sierra_Chart Engineering - Posts: 17145
We apologize for this, we only just became aware of it. We are correcting this now.
[2024-09-27 00:11:14]
This is now resolved in version 2684 which is a prerelease available now.
Update instructions:
