Date/Time: Fri, 22 Nov 2024 21:29:33 +0000
IBS Internal Bar Strength
View Count: 112
[2024-09-26 16:03:04]
bobstone249 - Posts: 28
Do you have a study available called the internal bar strength? You may refer to this as something else.
The Internal Bar Strength indicator is an oscillator that measures the position of the current trading session’s close relative to the session’s high-low range.
Many thanks
Rob
[2024-09-26 18:45:03]
John - SC Support - Posts: 36237
We have 400+ studies available and we do not know the information for every one of them. So we may have this, although we can not say what it may be - we definitely do not have it as "Internal Bar Strength". You can look through the studies we have available at the following link:
Technical Studies Reference
