Date/Time: Fri, 22 Nov 2024 21:06:28 +0000
Logatihmic scale displaying
View Count: 83
[2024-09-26 15:00:16] |
M.K Klyk - Posts: 2 |
Hi, got small problem with displaying log scale.Attached are examples from tradingview displayed correctly and same from sierra chart with simple pararell lines something is OFF in sierra when displaying LOG scale.
Attachment Deleted. examples.rar - Attached On 2024-09-26 14:56:23 UTC - Size: 305.97 KB - 68 views |
[2024-09-26 15:45:33] |
John - SC Support - Posts: 36236 |
Refer to the following setting: Chart Drawing Tools: Support Curved Lines On Logarithmic Scale (Global Settings >> Tool Settings >> General >> Other) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
