Date/Time: Fri, 22 Nov 2024 21:11:12 +0000
Trade Copier Q's- Apex accounts w/ Denali feed
View Count: 118
[2024-09-25 18:53:45] |
mnorf1 - Posts: 1 |
Hello, I'm looking to set up 5 (50k Rithmic) Apex prop accounts, purchase Sierra Chart Package 11 for charting, and open a funded trading account with Edge Clear using Teton Order Routing. I plan to use the Denali Data Feed. I understand I will need to connect the Edge Clear account to SC once every 30 days to avoid paying the high professional exchange fees through CME. I trade ES and NQ so I know I'll also need to get the CME w/ Market Depth for non-prof trading accounts ($12.50/mth) exchange fee package. I don't plan to actively trade with the Edge Clear account but to solely use it to get the lower non-professional exchange fees and to get access to the Denali Data feed. Is there a way to use the built in Trade Copier with Sierra Chart to only trade the 5 Apex accounts while using the Denali data feed or will this cause an problem? Are there any issues that you foresee with this setup? |
[2024-09-25 21:29:23] |
John - SC Support - Posts: 36236 |
You have your information correct with regards to the CME data. The general answer to your question is that there is no issue using our Denali Exchange Data Feed data with a trading service. This is actually our preferred setup, as we find issues with other providers data. Just so you are aware, our "Order Allocation to Trade Accounts" feature only works with trade accounts that are available under a single login. So if your Apex accounts are all tied together so that you use a single login to access them, then this will work. Otherwise, this feature does not work. Refer to the following: Order Allocation to Trade Accounts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
