Date/Time: Wed, 27 Nov 2024 12:37:42 +0000
using newline or carriage returns in alert formulas
View Count: 1001
[2014-09-04 10:44:19]
CycleTrader - Posts: 12
Some of my alert formulas are somewhat lengthy. I like to seperate the statements on separte lines.
It doesnt look like you can use the Enter key for a newline in the alert definition box.
So I use a regular text editor and then paste it in the alert box.
However that seems to mess up the alert functions.
Is there a way around this? Like shift enter or alt enter
Or do you need special encoding like DOS, UNIX etc)
rgds
Dick de Reus
[2014-09-04 17:22:25]
In version 1188 coming out today or tomorrow, in the non-CLR version, you will be able to enter newlines in formulas and it will all be properly processed.
