Date/Time: Fri, 22 Nov 2024 18:06:55 +0000
With update to new version - keep setting I and J column
View Count: 152
[2024-09-25 12:10:45]
pkhst958 - Posts: 57
I have set in study settings the "column I and J version 2" to "YES". When I update sc, this setting is set back to "NO". Just setting it back to "YES" does not help, sonce many settings are changed. I would like to just keep version 2 or a work around like to back up some file and copy it after update to some folder.
[2024-09-25 14:16:34]
Sierra_Chart Engineering - Posts: 17145
We apologize for this. We are checking on this now.
[2024-09-25 16:36:46]
We tested this, and we could not reproduce this problem. Provide that particular chart that contains the Spreadsheet Study.
Instructions:
[2024-09-29 13:01:45]
I have switched to version 1 as standard, so the issue is solved
[2024-09-29 13:29:18]
The other thing that should solve the problem being we cannot reproduce it is to remove the Spreadsheet Study from the chart and add it again and set Use Columns I and J Values Version 2 to Yes.
Date Time Of Last Edit: 2024-09-29 13:29:57
[2024-09-29 13:58:33]
Sawtooth - Posts: 4118
IMO, this is best practice.
[2024-09-30 13:53:08]
John - SC Support - Posts: 36222
Keep in mind, you can set the "Defaults" for a study, so if you want to use Version 2 of the I and J columns, then set that Input and then save that as your default for the study. Refer to the following:
Chart Studies: Using Custom Default Study Settings
